hydraulics
   / hydraulics #1
dogshow
2022 lovol tb504
hi, bought a 2022 lovol tb504 tractor, and got a quick mount blade for front loader, i am not getting to angle it each way, tractor as a 3rd function joystick, got no hyd. oil coming to cylinder ,tried bleeding, no work,tractor is new with 22 hours. i don't know if it is got to do with hydraulics or electrial,or the joystick itself.got any idea's.thanks.
   / hydraulics #2
Tractor hydraulics are self-bleeding. Try connecting to a different implement or cylinder. If it still doesn't work either, the problem is in your accessory control on the tractor. Often that control is a push button that works an electric solenoid that opens a valve to allow hydraulic fluid to flow. First thin to check is that voltage is getting to the solenoid.
   / hydraulics
thanks for your reply.i will check it out.
   / hydraulics #4
Wow, that's a nice tractor I hadn't heard of before. Must be for the Euro-Asian markets only. The no-DEF 50hp engine gave it away. And a remarkable 10-year, 3500-hour warranty is off the charts. Wish we had those here. I wonder if there's a rebadged equivalent in the US.
2018 John Deere R4038 Self Propelled Sprayer (A50657)
2018 John Deere...
2017 Ford F350 (A49461)
2017 Ford F350...
2014 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51219)
2014 FREIGHTLINER...
HANG ON 48" CATERPILLAR FORKS (A51242)
HANG ON 48"...
2008 CATERPILLAR 345CL EXCAVATOR (A51242)
2008 CATERPILLAR...
2006 Ford F-150 Pickup Truck (A48081)
2006 Ford F-150...
