hydraulics
/ hydraulics #1
donald59
uhland texas
kioti CK20
hydraulics just quit went down while using auger bit change oil and filters still no hydraulics
/ hydraulics #2
You need to give much more information! And maybe use some punctuation, just a little. Did this happen on your Kioti? Is it a 3-point PTO or skid-steer hydraulic auger? Exactly what do you mean by "hydraulics just quit went down"?
/ hydraulics
Yes was drilling post hole when down a won't come back up also bucket won't come back up also
/ hydraulics #4
Any strange noise? Does loader curl work? Does power steering work?
/ hydraulics #6
What drives your hydraulic pump? Can you see if its turning? Why did you choose to change the oil and filter? How many hours are on the tractor? Was it do due for a change or were you just grabbing at straws? Was there any different sound when this happened? Does the engine act like its under load or struggling to pump oil?
Cant really say much when all you give us is "it wont work". The more detailed you are, the better the responses you will get.
/ hydraulics
Change oil to grab straw no the engine doesn't sound like it laboring i was told since i hadnt change oil yet filters could be clogged the neighbor overfilled the hydraulic fluid I haven't been able to get a copy of the manual to see where the pressure relief valve is too if it's got too much pressure on the line to check that portion of it that's why I changed out the oil because it was over full
1998 Ferguson 46B Compactor / Roller (A62613)
1998 Ferguson 46B...
2016 PETERBILT 567 TRI AXLE ROLLOFF TRUCK (A65643)
2016 PETERBILT 567...
1999 MACK MIXER (A65643)
1999 MACK MIXER...
New/Unused Landhonor Pallet of Chains and Binders (A65583)
New/Unused...
Skid Steer Mount 3pt Adapter  (A62679)
Skid Steer Mount...
2012 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2012 CATERPILLAR...
