hydraulics
   / hydraulics #1
Modemman
St. Clair, MO
mahindra 6500
What is the easiest and cheapist way to add an extra set of couplers on a Duetz Allis tractor?
   / hydraulics #2
Tell us what you have for hydraulics.
   / hydraulics
it has one pair of couplers already, but to run a round baler, i need two pair.
i have another tractor to bale with, but wanted to have both in case something happen to the other, i could bale with the other.
I have seen valves to put into the existing one, and uses electric switch to use two at a time, but it is kinda expensive to me. Any help would be appreciated, JJ. Thanks
   / hydraulics #4
If your valve is a mono block valve you will have to add another valve in series.
If it is a stacked valve, you can add to the stack.
A selector/diverter valve will take one input and provide two outputs. Use a switch to switch between which cyl or motor.
   / hydraulics #5
Did it come new with the one you have now or was it added later? Might be able to just get a 2 or 3 spool valve and replace the old one.
2021 KENWORTH W900 TANDEM AXLE SLEEPER (A54607)
2021 KENWORTH W900...
Utility Trailer (A52377)
Utility Trailer...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A52141)
2006 CHEVROLET...
2007 CHEVROLET C4500 DUMP TRUCK (A51406)
2007 CHEVROLET...
2025 JMR 72in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 72in Dual...
MISC WRENCHES (A53843)
