Hydraulics Work and then Quit
   / Hydraulics Work and then Quit #1
AZTreeHugger
Flagstaff, Arizona
Kubota B5100
Hi. This has happened 3 times in a row.
I finally get it started (took some tricks in the cold), and the hydraulics work, yay, moving some snow around.
Then they just quit for no apparent reason.
The oil is milky. My friend thought it maybe had a chunk of ice getting caught in the pump?
It will work for about 20 minutes to a half hour, then quit.
Help!!! I was going to make snow moving a fun Christmas present for neighbors tomorrow.
TH
   / Hydraulics Work and then Quit #2
You have water in the fluid. If it gets cold enough it is going to freeze.
You probably need filters and screen cleaning.
You need a complete flush and new fluid.
Check fluid levels.
   / Hydraulics Work and then Quit #3
My thinking is that you have a serious suction leak some where. :eek: The milky oil is that way from all of the air in it. The longer the fluid gets pumped , the more air is mixed with the oil. After awhile when the hydraulics quite working is when you are actually pumping more air than oil. Just a theroy. :confused3: Sure sounds like you're getting air in there though.
When you check the fluid when the hydraulics quite working, is it at a higher level than before it becomes milky?
Good luck ;)
   / Hydraulics Work and then Quit #4
Check fluid levels.
Not saying that what you have said is not true, but if the hydraulics work when cold and then don't as they warm up, how is freezing got anything to do with his problem? :confused:
   / Hydraulics Work and then Quit #5
:welcome:
   / Hydraulics Work and then Quit #6
Drain some of the hyd fluid and let it set.
If it is air en-trained fluid, it will dissipate with time.
   / Hydraulics Work and then Quit #7
Correct, this is why I think that the system works at first and then quites. :confused3: Don't really know, just guessing. :eek:
   / Hydraulics Work and then Quit #8
Install a hyd gage to the IN port of the FEL valve and use it to monitor and trouble shoot the hyd system.
Air will cause erratic pressure readings.
   / Hydraulics Work and then Quit #9
Just a question. If you took a small sample of the milky fluid and put it in a glass jar and let it sit for a while, could you tell if the contamination was air or water? If it was water, would you see it settle to the bottom?
   / Hydraulics Work and then Quit #10
if it's air entrainment, it will settle out.. most utf oils anti-foam quickly upon setting.
if it is water emulsion.. it may settle to water and oil.. it may not.. depends on the addatives, emulsifiers..e tc. some emulsions can be stable..
air will settle out though...
2008 Ford F-450 Crew Cab Service Truck (A52377)
2008 Ford F-450...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
2015 JOHN DEERE 310K BACKHOE (A51406)
2015 JOHN DEERE...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2014 VOLVO A25G ARTICULATED DUMP TRUCK (A51406)
2014 VOLVO A25G...
UNUSED LANDHONOR LHR-AIW1-1" AIR IMPACT WRENCH (A54757)
UNUSED LANDHONOR...
