Loader Hydraulics wont hook up
   / Hydraulics wont hook up #1
ProudMarinedad
1997 New Holland 1630 Boomer
Trying to hook up my FEL back on my tractor. 2 hoses will connect but the other 2 wont. The center pin on male connector will not go in to complete hook up. Is there too much pressure in the hose. the center pin of the male connector will not budge. Anyone with any ideas would be a great help. thankx
   / Hydraulics wont hook up #2
Welcome to TBN:D
This happens a lot, especially if the loader is/was outside in the sun or it settled on soft ground. You can relieve the pressure by wrapping a rag over the QD nipple and pressing against the loader frame, or loosening it with two wrenches. It only takes a little fluid release to do the job.
Thanks for the info. I tried pushing the nipple in but it wont budge. i will try the wrenches.
   / Hydraulics wont hook up #4
I have wrapped the ball end in about 3 or 4 layers of shop towel, make sure you are wearing eye protection, and wack the end of the ball with a wooden hammer handle. Make sure there is no grit on the shop towel or the hammer handle, so as not to damage the surface of the ball. You WILL get some fluid on you even with the shop towel. This has worked for me.
James
K0UA
   / Hydraulics wont hook up #5
The ultimate solution for this problem is to buy four female quick connects and plug in your male fittings when the loader is off. To catch the seep, put a ziplock bag over the ends and secure it with a small bungee or rubber band.
Surplus Center has them for $3.95 each. 3/8" female QC (Pioneer compatible)
   / Hydraulics wont hook up #6
Now Jinman why didn't I think of that?. That would solve the whole temp change problem once and for all:thumbsup:
James K0UA
   / Hydraulics wont hook up #7
that ziplock baggie trick is a good one. I slip the 1g bags over my yoke ends of my mower pto shafts at the end of the season after greasing them up.. then secure with a zip tie.. keeps them clean and water/dirt free.. just cut the bag and tie off at the first use.
soundguy
2023 CFG QNT45 Mini Excavator (A49461)
2023 CFG QNT45...
2018 Bobcat T590 Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
2008 FORD F-750 (A50854)
2008 FORD F-750...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
SHOP MADE  MANIFOLD TRAILER (A50854)
SHOP MADE...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A51039)
2020 Massey...
