hydraulics return
   / hydraulics return #1
kgoring
I'm a hydraulics noob and am trying to figure out how to hook up a log splitter to my TC-33D. The pressure out is pretty obvious but where does the return line connect, to pressure return or to reservoir return? When would you use one over the other?
   / hydraulics return #2
Do you have a set of remotes you are tapping from.. or are you tapping hyds off another location.. like a diverter block.
Is your splitter spring return and SA.. or DA/hyd return?
soundguy
   / hydraulics return
It would be a DA/hyd return. No remotes on my tractor. I was planning on connecting directly to the hydraulic block on the right side of the engine by adding some quick couplers.
   / hydraulics return #4
If your splitter is using a DA cyl.. you will need a DA spool valve. If the splitter has it's own valve.. and it is OC.. it will need a pressureline from the tractor, and return line to the sump. Make sure you know what/where to tap power off of..
soundguy
2014 Utility Trailer 4000DX 53ft. T/A Dry Van Trailer (A51692)
2014 Utility...
2021 HAMM HD+9I VO DOUBLE DRUM ROLLER (A51246)
2021 HAMM HD+9I VO...
2020 KENWORTH T680 SLEEPER TRUCK (A52576)
2020 KENWORTH T680...
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
1271 (A50490)
1271 (A50490)
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
