Hydraulics Question
/ Hydraulics Question #1
Shemp
I've posted before that i have a hydro leak on my ML230 front loader on my 3525 where one of the lines goes into the pump. I haven't done anything about it but figure I would try to do it myself without having to haul it in 80 plus miles to get it fixed. It actually looks like it may be just a bad washer. From looking at my manual for the loader the line is a pressure line so it is a screw on at the valve not a quick connect. At the pump it is a screw on also and that is where the leak is coming from. What do I need to do as ar as starting to take the hose off at the pump? Do I need to drain the system completely or can I just unscrew it from the pump and let the fluid run out. Any other advice is greatly appriceated. Thanks.
/ Hydraulics Question #2
Shemp,
Put a drain pan under the line you are taking off, and start taking it apart.
2002 STERLING L7500 SINGLE AXLE BEVERAGE BODY TRUCK (A69167)
2002 STERLING...
OTTAWA SPOTTER TRUCK (A65057)
OTTAWA SPOTTER...
2016 KUBOTA SVL75-2 SKID STEER (A65056)
2016 KUBOTA...
1996 DODGE RAM 1500 LARAMIE SLT EXTENDED CAB TRUCK (A65057)
1996 DODGE RAM...
2005 STERLING L9500 MIXER TRUCK (INOPERABLE) (A67714)
2005 STERLING...
1960 (A65054)
1960 (A65054)
