Hydraulics Question
   / Hydraulics Question #1
Shemp
I've posted before that i have a hydro leak on my ML230 front loader on my 3525 where one of the lines goes into the pump. I haven't done anything about it but figure I would try to do it myself without having to haul it in 80 plus miles to get it fixed. It actually looks like it may be just a bad washer. From looking at my manual for the loader the line is a pressure line so it is a screw on at the valve not a quick connect. At the pump it is a screw on also and that is where the leak is coming from. What do I need to do as ar as starting to take the hose off at the pump? Do I need to drain the system completely or can I just unscrew it from the pump and let the fluid run out. Any other advice is greatly appriceated. Thanks.
   / Hydraulics Question #2
Shemp,
Put a drain pan under the line you are taking off, and start taking it apart.
John Deere 970 Cultimulcher (A52128)
John Deere 970...
2007 KUBOTA M5040F TRACTOR (A51243)
2007 KUBOTA M5040F...
2020 KUBOTA RTV...
UNUSED AGT SAWMILL (A51244)
UNUSED AGT SAWMILL...
2008 Ford F-250 4x4 Service Truck with Liftgate (A50323)
2008 Ford F-250...
SET OF CATERPILLAR SKID STEER PALLET FORKS MAST (A51244)
SET OF CATERPILLAR...
