Hydraulics Problam
   / Hydraulics Problam #1
mobsterb
Haysville Ks.
Kubota BX23
My BX23Kubota loader will lift, but won't power down also my out riggers will go down but won't retract. Thank You Mel
   / Hydraulics Problam #2
It appears that your loader has either some QD connection problems or a faulty spool.
Do you have float?
Same situation with the BH spools.
Can you observe whether the spool shaft is moving in and out of the bore the same amount?
Do all return hoses have a free path to tank.
What position is the 3pt lever? Should be in neutral.
Some tractors 3pt levers will return to neutral automatically, and others are friction levers and stay where you left them.
You might consider a hyd gage and use it to check pressures.
2025 Wolverine TL-12-72W 72in Hydraulic Tiller Skid Steer Attachment (A52378)
2025 Wolverine...
2023 Kubota LX2610SUHSD MFWD Compact Tractor with LA535 Front Loader (A55302)
2023 Kubota...
U56 DIESEL FIRE PUMP (A51406)
U56 DIESEL FIRE...
UNUSED EINGP SCL850 STAND ON SKID STEER (A54756)
UNUSED EINGP...
2014 Ford Escape (A50324)
2014 Ford Escape...
2018 CATERPILLAR 415F2 IL SKIP LOADER (A52705)
2018 CATERPILLAR...
