Hydraulics Pressure vs. Hand
   / Hydraulics Pressure vs. Hand #1
Thowle
Kentucky
John Deere 4066R Cab w/ H180 and 4-in-1 Bucket
Enough said.
   / Hydraulics Pressure vs. Hand #2
Had a boss once, brilliant in some ways but little common sense - he had a small Kubota, maybe 25 horse. Tractor was turned OFF, loader raised. He saw a small pinhole leak in one of the loader hoses, and put his THUMB over it??!? Nearly lost the thumb, still having problems with it over a year later.
My point - even without obvious power applied, STORED energy can hurt/kill you just as easy... Steve
   / Hydraulics Pressure vs. Hand #3
Hmm....well I wouldn't have thought the stored energy behind a leak would be sufficient to penetrate skin and cause problems...learn something new every day....agreed, remove pressure always from hydraulics when engine is not running.
   / Hydraulics Pressure vs. Hand #4
texasjohn, if you re-read my post the loader was RAISED at the time - so the weight of the loader pressing against the lift cylinders was the "stored energy" that supplied the hydraulic pressure -
I've been in industrial maintenance for the past 33 years, and we got safety training on everything you could possibly think of and a few things you would NOT normally think of - stored energy can come in the form of electricity (charged capacitors for example) weight supported by a latch that could fail, liquid or gas under pressure in a pipe, etc. -
I brought this up because I'm sure a LOT of our members did NOT have this sort of mandatory training and may not think of something as dangerous til it's too late. Thinking things through "just one more time" may save a body part or a life. 'Nuff said... Steve
   / Hydraulics Pressure vs. Hand #5
I knew to be careful, but that sure drives it home.
I had a line rupture on a backhoe years ago that shot out into my burn pile, didn't even see it until it ignited; scary stuff.
   / Hydraulics Pressure vs. Hand #6
Why was the loader left raised???
   / Hydraulics Pressure vs. Hand #7
Murphy, did you miss this? "little common sense' in my first post? This guy was actually an MIT grad, but so little common sense that nobody wanted to work with or near him, no joke. He could find so many ways to screw up by not thinking things through, and then so many ways to explain what happened (after it was too late). Downright scary... Steve
2017 Hino 268 20ft Flatbed Truck (A52377)
2017 Hino 268 20ft...
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
Pickup Instructions (A47477)
Pickup...
MAJOR LOT NUMBER 260 (A53084)
MAJOR LOT NUMBER...
Brush Bandit 200UC Towable Brush Chipper (A52377)
Brush Bandit 200UC...
2013 FREIGHTLINER BUSINESS CLASS M2 VACUUM TRUCK (A51406)
2013 FREIGHTLINER...
