Hydraulics on grey-market tractors...
   / Hydraulics on grey-market tractors... #1
davesisk
Platinum Member
Raleigh, NC USA
Massey-Ferguson MF 1220
Hey folks:
Just curious here...do any of the typical grey-market tractor models have enough hydraulic flow and pressure from the built-in pump and enough capacity in the built-in hydraulic reservoir to run a small 3PH backhoe? Or would pretty much all of them need the type of backhoe that is self-contained with it's own PTO-powered pump and it's own reservoir? I gather pretty much all of them have enough hydraulic necessities to run a loader with no problems.
By grey-market, I'm referring to Yanmar, Hinomoto, Mitsubishi, Iseki, and Shibaura.
Also, I don't recall ever seeing any that were HST rather than manual tranny's...please correct me if I'm wrong.
Thanks!
Dave
   / Hydraulics on grey-market tractors... #2
I can't comment as to the flow rate as I have never had a hoe on a grey market. From the speed at which my loaders have worked, I believe I would want the PTO vs tractor hydraulics. As for HST, I can tell you that Yanmar does make HST tractors now, but I have never seen one imported. The greys you see for sale are of a vintage that did not have HST.
   / Hydraulics on grey-market tractors... #3
I had a Yanmar with a loader and hoe. I used the remote pump. I could use the hoe and loader at the same time. It came in handy when you were in a muddy spot and needed to crab out. You couldn't do that if you used the tractor for both.
   / Hydraulics on grey-market tractors... #4
I had a Kelley B600 backhoe & loader on a YM1702d for 4 years as a rental unit using tractor hydraulics. . It had plenty of speed. I usually ran it at about half throttle. The hoe was rated 3.5-4.5 GPM.The tractor has 5-6 gpm pump.
2016 Nissan Altima 2.5 Sedan (A51694)
2016 Nissan Altima...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A53472)
Kubota 24in Quick...
Toro Workman MDX Utility Cart (A51694)
Toro Workman MDX...
Caterpillar 56in Excavator Bucket (A51691)
Caterpillar 56in...
Ford Tractor (A50120)
2015 KUBOTA 1140CRX RTV (A51406)
2015 KUBOTA...
