hydraulics on cub 5254
   / hydraulics on cub 5254 #1
carpenter56
Does the hydraulics on cubs model 5254 only have a one way pump for lifting so there would be no downward pressure on the 3 pt hitch, and the belly mower. Making it that the 3 pt hitch and the belly mower will raise quickly but lower at a much slower rate? I'm trying to purchase but was concerned about the slow rate that the belly mower lowered. (about 6-7 seconds to lower). That's when the dealer told me it had a one-way pump on the hydraulics and would probably loosen up with use. Any input will be appreciated.
   / hydraulics on cub 5254 #2
With weight on the hitch it goes down fine. With no weight it goes slower. Belly mower raises and lowers fine.
   / hydraulics on cub 5254 #3
What the dealer should have told you was that the hydraulic cylinder for the 3-point hitch is single acting which means it only has power up and gravity down operation. The speed at which the 3-point lowers is controled by a separate valve(round knob you turn) to increase or decrease the lowering speed. This is what controls the speed of lowering your MMM since it is operated by the 3-point lift arms. Sounds like the lowering speed knob is turned in too far which is making it lower slowly. Have him turn it to the fastest position then see how fast it drops(watch your toes!) It should not "loosen up with use", although some bleed down will be seen as time goes on. Your dealer is not very knowledgable about how the tractor's hydraulic system works.
Now for the pump. The implement pumps on these tractors and (99.99% of the others as well) are indeed "one way" but as I stated above that has nothing to do with the operation of the 3-point hitch. The only pump on the tractor that is bi-directional and variable displacement is the the pump for the hydrostatic drive unit, but that only powers the HST unit not the implements.
I hope this clears things up a bit more for you.
5' ATV Harrow (A50515)
4K SAND SEPARATOR (A52472)
4K SAND SEPARATOR...
2011 John Deere 844K Articulated Wheel Loader (A50322)
2011 John Deere...
UNUSED JCT QUICK ATTACH 84" ROCK GRAPPLE BUCKET (A51244)
UNUSED JCT QUICK...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
UNUSED MOWER KING SSB72 BOX BROOM (A51244)
UNUSED MOWER KING...
