Hydraulics needed to put thumb on Kubota L4400?
   / Hydraulics needed to put thumb on Kubota L4400? #1
tallyho8
Elite Member
North of the Gulf of America, west of Westwego
Kubota L4400, Kubota ZD326
I bought a one cylinder thumb to put on the front end loader of my Kubota L4400. I know very little about hydraulics. Can anyone familiar with an L4400 tell me what I need to get to hook up the hydraulics to this thumb?
   / Hydraulics needed to put thumb on Kubota L4400? #3
Do you have a rear remote? If so that is the cheap and dirty way. Not elegant but will work..
   / Hydraulics needed to put thumb on Kubota L4400? #6
A 3rd function works best but running it off of a remote will work.
   / Hydraulics needed to put thumb on Kubota L4400? #8
I have a 2005 L4400 that I added a W.R. Long third function kit with a switch on the bucket control arm and what I call a grapple mounted in the center of the bucket. I did it all myself (with a little advice from the tractor mechanic) so it can't THAT hard. Hope you're not in a hurry but I can take pictures, get part numbers, etc. maybe this weekend. Seem to remember that it cost me about $1K and still works great 5 years later. Maybe my favorite addition to the tractor, but that's still debateable...
   / Hydraulics needed to put thumb on Kubota L4400? #9
Tallyho8, Do you only want to run a thumb / grapple? The electric diverter is nice but (IMO) pricey. A single valve/spool like Surplus Center - 1 SPOOL 8 GPM PRINCE MB11B5C1 DA VALVE will work, your tractor's 7.8 GPM and this is rated for 8 GPM (if you also want a hydraulic top link, this one Surplus Center - 2 SPOOL 8 GPM PRINCE MB21BB5C1 DA VALVE will work). Along with hoses with the correct fittings on the ends (which are not cheap) you can get this set up cheaper.
I would say the main thing is mounting it in a good location first since all the hose measurements will be based on that location. I have mine just above the loader mount and with some fancy finger work, can curl and close the grapple at the same time (after I cut my loader stick down 7" or so). Also, with this location I was able to re-use the hoses that was used for the loader.
Basically, I mounted my valve after the loader and before the 3 point hitch, it has to be in series. The line that was power beyond for the FEL was moved to be power beyond for the grapple spool. I added a new line from the old power beyond into the pressure IN for the new valve. The low pressure return to the tank, I tied into the FEL low pressure return with a "T" (right where both valves are at).
Let me know, I can go into better detail... Dan/teg PS. the TBN jacket (that you auctioned off) still keeps me warm although, showing a little wear and tear... :thumbsup:
   / Hydraulics needed to put thumb on Kubota L4400? #10
I will let you know how my rear remote idea works out, my grapple is due to arrive in a couple of days.
2018 UTILITY VS2DC 53FT REEFER TRAILER (A52141)
2018 UTILITY VS2DC...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
Marliss Industries Grain and Soybean Drill - Selling ABSOLUTE NO RESERVE (A52748)
Marliss Industries...
CAT D16 LGB (A50322)
197711 (A51244)
197711 (A51244)
TMA (A49461)
TMA (A49461)
