3-Point Hitch hydraulics leaking down
   / hydraulics leaking down #1
chip6700
i just purchased a new b2320 and if i turn off the tractor with the blade on the back all the way up, within 2 hours it will be on the ground. it also leaks down a little while the tractor is running.
the dealer had it for 2 weeks and replaced the "valve" (they said that's all there is to the rear hydraulics) and it didn't fix it. originally they though it was a spring that kept pressure on the control that raises and lowers the hydraulics. then they said it was probably an o-ring. my question is, have many people or really anyone experienced this problem on a new tractor.
   / hydraulics leaking down #2
If this under warranty keep on them untill resolved.
it's definitely under warranty. i was just curious if others had experienced this. the dealer said they don't know what else to do and is having to contact the kubota service rep. some people on another site said that it's to be expected that they might leak down, but i can't believe it's the norm.
   / hydraulics leaking down #4
Leaking down while shut off is one thing, and fairly normal. Leaking down while running isn’t normal.
   / hydraulics leaking down #5
You can isolate whether it is in the valve or the o-ring on the piston by closing the valve under the seat that controls the implement drop speed. Raise the implement all the way up, close the valve, and shut the machine off. If the implement still drops it is the o-ring on the 3-pt piston, if it doesn't drop, then it is in the control valve.
Brian
PS. Fill out your info so we know where you are located, it could help someone point you in the direction of another dealer or trusted repair facility.
   / hydraulics leaking down #6
I have ballast weight on my 3PT for the winter, it hasn't leaked down at all since I hooked it up last November. It's only a few hundred pounds. I've left my FEL up overnight and it doesn't leakdown at all that I can detect by eye.
thanks for your responses. hopefully the dealer will step up and fix.
2007 Chevrolet C4500 4x4 Dump Truck, VIN # 1GBE4C3247F411826 (A51572)
2007 Chevrolet...
Deutz-Allis GVL Poly Corn Head (A50514)
Deutz-Allis GVL...
Miles,26,126 (A50323)
UNUSED X-STAR 101" X 20' LOADING RAMP (A51243)
UNUSED X-STAR 101"...
2005 MACK GRANITE GU713 DAY CAB (A51219)
2005 MACK GRANITE...
2019 CATERPILLAR D6K2 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
