Hydraulics help!!!
/ Hydraulics help!!! #1
RPK
Eastern CT
Kubota L3130 Cub Cadet 1554
I am still beating this 3ph log splitter around. I called my Kubota dealer to talk about setting up the splitter. They said if I was planning on any other rear mounted implements I should consider remote hydraulics. I am considering a self feeding chipper. They want $900.00 to install remote hydraulics.
I have the two separate lines that connect to the BH90. Is this called power beyond??
They said the advantage with remote hydraulics is the splitter could be removed without worring about reconnecting the two lines. I am a little confused. Will those two lines go away and I will connect the backhoe to the remotes or will those two stay for the backhoe only??? I know as long as those two lines are there they must be connected to each other or the BH90.
Thanks for all your help guys. I'm slowly learning.
RPK
L3130 LA723 loader BH90 Forks and a 7' rake
2022 EZ-GO ELITE...
2017 Nissan Altima 4 door (A63689)
2017 Nissan Altima...
2006 Mack Granite CV713 Dumping Flatbed (A62679)
2006 Mack Granite...
International S1900 (A63689)
International...
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
2000 CATERPILLAR 988F WHEEL LOADER (A62129)
2000 CATERPILLAR...
