Hydraulics for county line log splitter and John Deere 5100e
   / Hydraulics for county line log splitter and John Deere 5100e #1
halfwayhome
bowling green ky
john deere 5100e
Can any one give me a tutorial on getting my log splitter to work from the splitter control handle. I can get it to work if I'm in tractor holding lever back and assistant at splitter controlling that lever. I need it to be a one man operation. I am over looking something. I don't know what it is. Thanks in advance.
   / Hydraulics for county line log splitter and John Deere 5100e #2
Bungee cord
Has to be a better solution.
   / Hydraulics for county line log splitter and John Deere 5100e #4
Nope 'fraid not unless you have a "power beyond" connection for something like a three point hitch backhoe. Bungee cords work well for 3 point splitters; I have had one for years. w jones
   / Hydraulics for county line log splitter and John Deere 5100e #5
Change the tractor valve to one with detent or maybe add detent to the valve you have. You can place it in detent and it will be the same as you holding it in.
   / Hydraulics for county line log splitter and John Deere 5100e #6
My Power Beyond has a lot more GPM than my third valve and bungee cord. Splitter runs a lot faster.....
   / Hydraulics for county line log splitter and John Deere 5100e #7
Does your tractor have a loader? If so, use PB hose.
You could install this valve in the line/hose going to the 3pt ,and feed the 3pt or the log splitter and run the log splitter OUT hose to tank.
Controls two hyd circuits.
Simple, easy and convenient.
1/2" NPT 20 GPM PRINCE SELECTOR VALVE
Pull knob for other circuit.
I do have a loader. I have a triple mid valve that I control grapple and loader with from joy stick. I have two rear remotes. Thank you for you response. I appreciate it.
   / Hydraulics for county line log splitter and John Deere 5100e #9
You can add this Power Beyond kit, its designed to feed a rear implement that has it's own control valve like a backhoe or log splitter.
John Deere POWER COUPLER KIT LVB25697
   / Hydraulics for county line log splitter and John Deere 5100e #10
2010 Ford Fusion Passenger Car (A51694)
2010 Ford Fusion...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
2018 Jaguar XE Sedan (A50324)
2018 Jaguar XE...
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
2015 Hyundai Veloster Hatchback (A50324)
2015 Hyundai...
Honda EU3000is Gasoline Companion Inverter Generators (A51691)
Honda EU3000is...
