hydraulics for a yanmar 1610 tractor
   / hydraulics for a yanmar 1610 tractor #1
1TomV
I would like to extend the hydraulics from the tractor system to a front loader , is it possible to come out of the pressure valve under the seat or not . Any help would be appreciated thank you!
   / hydraulics for a yanmar 1610 tractor #2
The recommended method is to cut the hi pressure line just after it exits the pump, attach a compression fitting for your hose, connect your hose to your FEL valve, run a line back to the hi pressure line, then connect just after the cut with a second compression fitting. This is a very simple and proven successful. When I first connected my FEL I connected to the draft control valve. It was too slow because it was restrictive.
2011 JOHN DEERE 329DT SKID STEER (A51242)
2011 JOHN DEERE...
Case Ih 1660 Combine (A50514)
Case Ih 1660...
M & M Grain Drill (A50515)
M & M Grain Drill...
2009 L3 GENERATOR SET (A51222)
2009 L3 GENERATOR...
2023 Trailerman Gooseneck (A50514)
2023 Trailerman...
John Deere LX5 3 pt Rotary Mower (A50515)
John Deere LX5 3...
