hydraulics for a yanmar 1610 tractor
   / hydraulics for a yanmar 1610 tractor #1
1TomV
I would like to extend the hydraulics from the tractor system to a front loader , is it possible to come out of the pressure valve under the seat or not . Any help would be appreciated thank you!
   / hydraulics for a yanmar 1610 tractor #2
The recommended method is to cut the hi pressure line just after it exits the pump, attach a compression fitting for your hose, connect your hose to your FEL valve, run a line back to the hi pressure line, then connect just after the cut with a second compression fitting. This is a very simple and proven successful. When I first connected my FEL I connected to the draft control valve. It was too slow because it was restrictive.
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A52128)
2022 MAXXD BD14...
2017 MACK CHU613 TANDEM AXLE SLEEPER (A51222)
2017 MACK CHU613...
2012 Ford Escape SUV (A50324)
2012 Ford Escape...
2012 CATERPILLAR 308E CR EXCAVATOR (A51242)
2012 CATERPILLAR...
John Deere 700 Hydraulic Hay Rake - Durable Side Delivery Rake for Efficient Windrowing (A52128)
John Deere 700...
2018 CATERPILLAR 336FL EXCAVATOR (A51222)
2018 CATERPILLAR...
