Hydraulics: backhoe only works with 3point chained down.
   / Hydraulics: backhoe only works with 3point chained down. #11
Is there a chance there is some type of manual diverter valve that needs to be switched when the hoe is on? I seems to reminder some Kubota's had them, maybe MH does also?
Shame more MH owners wont jump in to help out :confused3:
   / Hydraulics: backhoe only works with 3point chained down. #12
Check you port block. sounds like diverter valve is in wrong position.The 3015 is equipped with this item. Not a good idea to run with 3 pt chained down and lever pulled back this unit is equipped with draft control. That will constantly deliver oil to the lift piston and cause the packing to eventually fail.
2016 John Deere 6110M Utility Tractor (A50657)
2016 John Deere...
Willmar 4300 Wrangler Loader (A51039)
Willmar 4300...
2018 PETERBILT 567 (A50854)
2018 PETERBILT 567...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
OIL WORKS INC. AIR TONGS (A50854)
OIL WORKS INC. AIR...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A51039)
2016 Ford F550 4x4...
