Hydraulics at 5 deg F
   / Hydraulics at 5 deg F #11
That radiator cover is the cure, I'll bet. According to the temp gauge, this model B never raises temp in the summer even when being pushed real hard at mowing. My BX used to run on the hot side when pushing it in the summer. I don't think that I even looked at the temp gauge while moving this last big snow at 5 deg F. When working the FEL, lifting and looking for a place to dump; and then dropping the RB etc., I think I forgot to notice the gauge. Thanks, everybody.
Cheers,
Mike
Kubotas staying that cold seem to be pretty common. Don't confuse coolant temperature with hydraulic fluid temperature.
I have a GST, is 2000 RPM normal operating for the HST? I thought the RPMs would be higher. Higher RPMs = more pump flow = more heat.
   / Hydraulics at 5 deg F #12
The Grands have auto throttle to synchronize power, RPM & HST output. The basic HST will run at whatever RPM its set at. The higher the RPM, the more power or speed you have & the less likely to lug the engine (but burns more fuel, makes more noise, etc.)
Okay, today I moved some more snow at 12 deg F. I covered about 2/3 of the radiator with a sheet of cardboard. Result: a little better hydraulic response with the FEL and RB; but it was also warmer today. The temp gauge moved up only a little off the "cold" peg. I'm good with this result however. Later I'll make a better radiator screen that fits on the outside of the grill. 2000 rpm is adequate for what I'm doing. Maybe if the runs were longer I could boost the rpm at mid-range where I work it. And, yes, higher rpm would create more heat for the HST. The HST filter never did get warm after a 15 minute warm up at about 1800 rpm.
2023 Bobcat T66 (A50120)
2023 Bobcat T66...
2014 Chevrolet Silverado (A55788)
2014 Chevrolet...
378813 (A51573)
378813 (A51573)
2011 Chevrolet Malibu 2LT Sedan (A55853)
2011 Chevrolet...
CAT FORKS W/ QUICK CUPPLER ATTACHMENT (A53843)
CAT FORKS W/ QUICK...
2018 RAM 2500 SERVICE TRUCK (INOPERABLE) (A53843)
2018 RAM 2500...
