Hydraulicaly driven 8cu.ft. cement mixer????
   / Hydraulicaly driven 8cu.ft. cement mixer???? #1
Sawdustsmb
Greene, NY
TL80a, Ford 4000, Super H, F 12, F14
I picked up a Cosmo 3pt hitch, pto, cement mixer a while back. Previous owner cut the pto shaft real short and I will need to replace it. Now I am wondering if it could be driven with a hydraulic motor using the tractor hydraulics which would then allow it to be mounted on the front loader. Started looking at hyd. motors in Surplus Center and not being a hydraulics expert I find that quite confusing! I bet someone out there knows the answer! Thank you. Bob
   / Hydraulicaly driven 8cu.ft. cement mixer???? #2
Which tractor are you looking at using? Can you post a picture of the mixer?
Looks like most mixers are ~20RPM, so that is the speed you want on the drum itself.
Thanks
Aaron Z
   / Hydraulicaly driven 8cu.ft. cement mixer???? #3
If you have about 10 GPM and can drive the mixer directly at about 100 rpm, you will need a hyd motor with a displacement of about 20 cu in. Less GPM, less speed.
If you use a 3 cu in motor and reduce the speed to about 70 rpm, using a 10 to 1 ratio you can use a 3 cu in hyd motor.
10 GPM into a 3 cu in motor will run it at 770 rpm. To high for a mixer, therefore the 10 to 1 ratio.
By changing the engine rpm, your pump will produce different GPM's.
28537[2].jpgThanks Aaron and J.J. It looks like the Operators manual on the NH TL80a says the flow rate can be turned down to a min. of 10 l/min. from 51. I don't know what the output on the Ford 4000 is but as you said JJ both tractors can be and would be idled way down. The mixer has a 10 to 1 reduction ratio built into it if I were to hook up to the PTO connection shaft.
Thank you
Bob
   / Hydraulicaly driven 8cu.ft. cement mixer???? #5
At 150 pounds per cubic foot of concrete, 8 cubic feet will weigh 1200 pounds. Plus the weight of the mixer and overhang. Will your FEL handle that much weight?
Yep, 2400lbs. to max. height - 31.5 inches forward of the pivot pin. Good thought though - might want the big back blade or some other heavy 3 pt. ballast on.
2000 Ford F-350 Stakebody Flatbed Truck (A51692)
2000 Ford F-350...
New Holland Hay Elevator (A50775)
New Holland Hay...
2008 CATERPILLAR 12M MOTOR GRADER (A51406)
2008 CATERPILLAR...
2018 SKYJACK SJIII3219 ELECTRIC SCISSOR LIFT (A52705)
2018 SKYJACK...
2018 INTERNATIONAL 4300 26' REEFER BOX TRUCK (A54607)
2018 INTERNATIONAL...
SEET BOX W/ CABLE SLINGS (A54757)
SEET BOX W/ CABLE...
