Hydraulic winch advice
   / Hydraulic winch advice
I believe the RS series White motors are considered their light duty line.
At 293.07cc that would make it one of their 300 series motors.
I believe your flow rate is going to be a struggle utilizing that motor.
We will find out. These winches are sold to be run off power steering pumps which are normally less than 4 gpm. I'm sure it'll be slow compared to a PTO winch.
I guess this thread should be in the hydraulic forum, but oh well.
This winch is rated as 1500psi max. How do I go about reducing the pressure but not flow? Will a crossover relief aka cushion valve accomplish this?
What is the danger of too much pressure? Blowing a seal in the motor? Stripping gears in the winch?
   / Hydraulic winch advice #23
You can add a PRV (pressure relief valve), or adjust the one that is already in your system.
That will reduce the max pressure to all implements though.
I did the opposite and increased my PRV around 20%.
What would happen; if the difference is small, 25%, nothing will happen. 25-50% probably nothing will happen but you never know, 50-100% over pressure, then you're really pushing your luck.
What would fail first is really down to the engineering of the thing. Generally, the safety factor of the mechanical parts should be at least 5, so the weak point is the hydraulic motor. Most likely the seal would fail first.
I have a hydraulic motor on my hedgecutter rated at 150 bar (2200psi); I have the PRV set at 225 (3250psi) and so far it's doing just fine.
Note that normal running pressure is only around 60 bar (900 psi), it only goes high briefly when it hits something tough, or stalls.
I recommend the installation of a pressure gauge. I don't know why they aren't standard.
  • Good Post
Reactions: JJT
2015 CASE SV280 SKID STEER (A60429)
2015 CASE SV280...
FORKLIFT (A56857)
FORKLIFT (A56857)
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
Killbros 260 Seed Conveyor (A56438)
Killbros 260 Seed...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2001 CATERPILLAR CB-634C SMOOTH DBL DRUM ROLLER (A60429)
2001 CATERPILLAR...
