Hydraulic vent, and water
   / Hydraulic vent, and water #11
For what it's worth: You might catch some foamy oil in a clear glass jar and cap it. Let it sit a while (might take a day) and I think the water will separate out. That way you'll know if it's a water or air problem.
<font color="red"> You might catch some foamy oil in a clear glass jar and cap it. Let it sit a while (might take a day) and I think the water will separate out </font>
Good idea. I am also going to crack open the drain plug and see what comes out. It has been sitting for a bit, and the plug is on the bottom
   / Hydraulic vent, and water #13
Yeah well. I'm not very good at "cracking" a drain plug. It's usually all or nothing with me. Still you should get a drip and that's all you need.
   / Hydraulic vent, and water #14
Hi, just thought I'd poke my nose in a little. I have an International 3400 backhoe that drove me crazy for a long time with foamy hydraulic oil, and cavitation. A diesel mechanic friend of mine finally came over and we trouble shot one day. When I would rev up the engine, the hydraulic pump would begin to cavitate, but would slowly stop making noise . As it turned out , air was being sucked in thru an o-ring and it was just luck that we found it. After this experience, I 'd go over any and all connection that you have--replace any o-rings--make sure everything is air tight. My mechanic friend told me water in hydraulic fluid turns it a milky white, depending upon how much water you have in the system. Foam is air in the oil. Hope that helps.
2018 UTILITY VS2RA 53FT REEFER TRAILER (A56129)
2018 UTILITY VS2RA...
2017 HITACHI ZX350LC EXCAVATOR (A54607)
2017 HITACHI...
2004 Ford F-350 4x4 Flatbed Truck, VIN # 1FDWW37P44EC81012 (A54865)
2004 Ford F-350...
NEW Thiessen Track Closer Disk (A55302)
NEW Thiessen Track...
PALLET OF NYLON SLINGS, METAL TOOLBOX W/ CHAINS (A54757)
PALLET OF NYLON...
2018 Club Car Carryall 1500 Diesel Utility Cart (A55787)
2018 Club Car...
