Hydraulic valve
   / Hydraulic valve #1
Varmint1
Deville,La
JD 1010, JD 970, Farmall Super A,Komatsu D20A-5,Ford 4500,Ford 4000 forklift,Ford 640 w/703 loader
This valve came off of an 941. Can anyone tell me if its single acting or does it work double (pressure and return)
   / Hydraulic valve #2
i'd see what's under that silver headed 'bolt'
if it is another oil port. it may very well be a da valve, however in SA mode. many do this with a small valve you turn / screw in.. more modern ones use a sleeve sometimes..
ports may be 3/8 orb.. which by the way is 9/16 fine bolt thread.. non taper. which is what that 'bolt' may be...
2006 CATERPILLAR 312CL EXCAVATOR (A51406)
2006 CATERPILLAR...
CAT JUMP BOX (A53843)
2012 TROXELL COMPANY 130BBL VACUUM TRAILER (A53843)
2012 TROXELL...
2015 MACK CHU (PINNACLE) TRI AXLE(INOPERABLE) (A53843)
2015 MACK CHU...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A54814)
2012 Crane Carrier...
2012 DRAGON 200BBL ALUMINUM TANKER TRAILER (A53843)
2012 DRAGON 200BBL...
