Hydraulic valve upgrade
   / Hydraulic valve upgrade #1
deans
Ontario, Canada
A/C c, Yanmar 155D, Kubota
I would like to relace my single spool, power beyond valve that I added to angle my rear snow blade, and add a new valve that will operate a newly built front snow blade. At the moment, I just have a single double acting lift cylinder and will be adding two single acting cylinders for left / right angling. What should I look for in a new valve and any tips in adding the additional plumbing needed. The tractor is a Yanmar 155D. Thanks and Happy New Year, deans
   / Hydraulic valve upgrade #2
You can plumb 2 single cylinders like 1 double acting cylinder in that case. Run one line to one cylinder and the other line to the other cylinder. I would put a double relief "cushion valve" between the valve and the cylinders. Then if you hit something like a curb or stump, it will give and not break.
Are you also looking to get a 2 spool or even a 3 spool valve so you can keep the rear angle and have the front angle (and maybe a spare for future need)?
23018 (A53424)
23018 (A53424)
2022 VERMEER RTX250 WALK BEHIND TRENCHER (A53843)
2022 VERMEER...
2016 WESTERN STAR 4900 HYDROVAC (A53843)
2016 WESTERN STAR...
2022 DRAGON  130BBL VACUUM TRAILER (A53843)
2022 DRAGON...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
4- 12 TOM JACK STANDS (A53843)
4- 12 TOM JACK...
