Hydraulic valve upgrade
   / Hydraulic valve upgrade #1
deans
Ontario, Canada
A/C c, Yanmar 155D, Kubota
I would like to relace my single spool, power beyond valve that I added to angle my rear snow blade, and add a new valve that will operate a newly built front snow blade. At the moment, I just have a single double acting lift cylinder and will be adding two single acting cylinders for left / right angling. What should I look for in a new valve and any tips in adding the additional plumbing needed. The tractor is a Yanmar 155D. Thanks and Happy New Year, deans
   / Hydraulic valve upgrade #2
You can plumb 2 single cylinders like 1 double acting cylinder in that case. Run one line to one cylinder and the other line to the other cylinder. I would put a double relief "cushion valve" between the valve and the cylinders. Then if you hit something like a curb or stump, it will give and not break.
Are you also looking to get a 2 spool or even a 3 spool valve so you can keep the rear angle and have the front angle (and maybe a spare for future need)?
2019 FREIGHTLINER SPRINTER 2500 CARGO VAN (A54313)
2019 FREIGHTLINER...
MASTER FLOOR HEATER (A53843)
MASTER FLOOR...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A53473)
2-Row Peanut...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
METAL FILING CABINET (A53843)
METAL FILING...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A51691)
2015 Toro Multi...
