Hydraulic valve + top cylinder and associated hoses assistance
   / Hydraulic valve + top cylinder and associated hoses assistance #1
SilencedNine
Kubota L2501
I have a valve picked out (2 spool to add a tilt later on) - https://summit-hydraulics.com/produ...-control-valve-2-spool-w-single-float-11-gpm/
I have a top cylinder picked out - Amazon.com: Hydraulic Top Link Cat. 1-1 with Locking Block 20 7/8” - 31 7/8” with 2 x Hose : Patio, Lawn & Garden
What is the best way to go about getting all the hoses and fittings selected/ordered/made, etc? Getting the correct fitting type and size to make all the connections seems like a fairly daunting task. What is the best approach?
   / Hydraulic valve + top cylinder and associated hoses assistance #2
With out having the valve mounted and top link installed you would be guessing at required fittings and hoses.
mince installed you can then take a piece of air hose and use that as a template for figuring out how the lines will run and what fittings you will require.
   / Hydraulic valve + top cylinder and associated hoses assistance #3
Don't forget to get the Power Beyond sleeve for that valve. Should be labeled as P40 Power beyond sleeve or carry over plug.
   / Hydraulic valve + top cylinder and associated hoses assistance #4
I mounted my valve first. I then I over thought the process, the two hydraulic hoses that came with the top link, I put quick couplers on the end (thinking I might remove it sometime, yup, never even thought about doing that...)
Ever thinking about adding a grapple down the road? For not much more money, you can go with a 3 spool. https://summit-hydraulics.com/produ...pm/?attribute_float-option=Single+Spool+Float This one doesn't have a float and adding a float is $209 but out of stock.
And you do need the power beyond sleeve.
Power beyond sleeve is in cart, I neglected to list it. I just might go with a 3 valve because why not. You never know what you might want to add in the future.
I suppose my primary concern is how do I determine what the Kubota OEM fitting sizes are? I will have to run a new line from the PB port on the FEL to the valve and from the valve back to the manifold under the step, and also also a return to tank line. Does anyone know what OEM fitting type/size these are?
   / Hydraulic valve + top cylinder and associated hoses assistance #6
#8 JIC.
   / Hydraulic valve + top cylinder and associated hoses assistance #7
Call your dealer to be sure but if they have not changed the Standard L's used to be SAE 8. {edit: I see MtnView listed another, he knows best - and is most likely more up todate} Again, ask the your dealer...
I used hoses that had 3/8 NPT but I tied in Parker needle valves for the top and side links. Allows for precise control. Grapple just needs open / close.
I used a bunch of 45* and 90* adapters that could have been built right on the hydraulic hoses. Discount Hydraulic hoses, I would call them once you know what ends you need and have the valve mounted so you can meeasure it correctly. Use a water hose to route your lines to where you need them, and measure the hoses.
For the record, I mounted my valve right on top of the FEL control. I did that since I could just move lines from the FEL to the new valve and buy one hose to connect the two together.
I used flat 1/4" stock with threaded rod to make a place to mount the new valve (one threaded rod went through the new spool, the 1/4" stock which continued into the original hole the the plastic cover for the FEL was held on to.
I removed the power beyond from the FEL, screwed it in to the new valve, bought a hose to loop from the FEL power beyond and screwed it into the new valve's IN port (power in). Then since the two return to tanks were so close, I used a "T" adapter to connect the two together.
It's a real birds nest but it's totally out of the way.
   / Hydraulic valve + top cylinder and associated hoses assistance #8
One other thing... for others that might be reading, your valve that you picked had "Float" but the hydraulic top link had a "Check" valve on it which would not allow it to use the "float" feature!!!
"...This top link is equipped with a locking block. With this valve, the oil is enclosed in the cylinder by a check valve..."
Also found more photos.... again not sure what might have changed over the years for the Standard L's FEL.
Right. The valve I listed has one float and one non-float spool. The float is for the future side/tilt cylinder. I intended to use the non-float for the top. It's a noteworthy comment though, for other readers. Thanks.
New/Unused CFG Industrial XZ20R Mini Excavator (A51573)
New/Unused CFG...
2017 Ford 550 XL, Cab and Chassis, Crew Cab (A52384)
2017 Ford 550 XL...
Ryobi Sliding Compound Miter Saw (A51573)
Ryobi Sliding...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
John Deere Z915E Zero Turn (A51573)
John Deere Z915E...
