Hydraulic Valve Sizing Question
   / Hydraulic Valve Sizing Question #1
Gordon Gould
Super Member
NorthEastern, VT
Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
My L3010 has a 7 GPM hydraulic capability. If I was going to choose between a 8 GPM max or 20 GPM max single spool dual acting valve to control my grapple would one be better choice than the other? Independent of size and cost. Thanks.
   / Hydraulic Valve Sizing Question #2
It does not matter as long as the valve is rated equal to or greater than the pump output.
I would choose the 8gpm unit because it is probably physically smaller and easier to mount than the 20gpm valve.
   / Hydraulic Valve Sizing Question #3
The 20 GPM valve might also not respond so well on "feathering".....feathering works better if the valve flow rating corresponds to the pump flow....using a way over sized valve, will be like trying to fill a little shot glass with water using a fire hydrant valve....
Thanks for the info. Sounds like all good reasons to go for the 8 GPM unit.
gg
2006 CATERPILLAR D604S GENERATOR (A48992)
2006 CATERPILLAR...
2015 Geringhoff NS830 (A47164)
2015 Geringhoff...
2022 Unverferth Seed Pro 410 (A47164)
2022 Unverferth...
2011 Ford Crown Victoria Sedan (A48082)
2011 Ford Crown...
2018 GENIE GS-1930 SCISSOR LIFT (A48992)
2018 GENIE GS-1930...
2013 UTILITY 53X102 DRY VAN TRAILER (A50046)
2013 UTILITY...
