hydraulic v alve between hyd cylinders and tractor.
   / hydraulic v alve between hyd cylinders and tractor. #1
gravelman
Platinum Member
NH
Kubota 2650
I want to mount a snowplow on a quick attach skid steer plate, have to weld ears to the plate. do i need a valve between the two snowplow angling pistons before ii connect to my third valve on the front on the tractor. i think i have heard it referred to as a "cushion" valve?? Ive seen them on some and not on others..thanks
   / hydraulic v alve between hyd cylinders and tractor. #2
ITs called a crossover relief valve. IT is their to protect everything if you hit something. Usually the first thing that goes if you hit something is you blow hoses and get a face full of oil.
A ~$80 crossover relief is cheap insurance. Do you have to use it.....NO. Is it suggested....yes.
THANK YOU VERY VERY MUCH
2017 Bobcat E20 Excavator (A52384)
2017 Bobcat E20...
Sears/Craftsman Shredder (A51573)
Sears/Craftsman...
2018 E-Z Beever M12R Towable Brush Chipper (A50322)
2018 E-Z Beever...
2018 CATERPILLAR 318FL EXCAVATOR (A51246)
2018 CATERPILLAR...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
