Hydraulic/Transmission Oil
   / Hydraulic/Transmission Oil #1
SH3
Kioti DK65S
Can anybody recommend which oil to use? I just purchased land and this Kioti DK65S with 15' brush hog came with it and the dipstick is showing no fluid in it. I can't find a manual form it so looking for suggestions. Thanks
   / Hydraulic/Transmission Oil #2
For the Kioti you can use TSC premium hydraulic fluid. Many on the board use it.
For the brush hog, I think you need to use gear oil 80-90 wt for that. Your post is somewhat ambiguous as to which machine you want input for.
Not trying to be a smart-butt, just an observation.
   / Hydraulic/Transmission Oil #3
For the brush hog, I think you need to use gear oil 80-90 wt for that duffer
a number of rotary cutter gearboxes also go w/85/140 hypoid
can't say in your case, bet another forum member will.... but need to know the make/model of hog
   / Hydraulic/Transmission Oil #4
Any of the good THF fluids is fine. The Tractor Hydraulic Fluid (THF) is also good for the transmission and wet brakes vs a hydraulic fluid that would be just for hydraulics. I have had good luck with Chevron THF 1000. My local store has it in bulk. The nicer stuff will work better when cold- you won’t get the groaning noises. Some love and some hate the TSC fluid.
INDUSTRIAL PIPE BENDER (A51248)
INDUSTRIAL PIPE...
APPROX. (13) NEW 24' SPAN 4/12 TRUSSES (A51248)
APPROX. (13) NEW...
Caterpillar 308E2 CR Midi Excavator (A52377)
Caterpillar 308E2...
Hydraulic 80 mm pin thumb & coupler combo (A52384)
Hydraulic 80 mm...
PALLET OF MILITARY STRAPS (A51248)
PALLET OF MILITARY...
