hydraulic/transmission fluid?
   / hydraulic/transmission fluid? #1
george88
Howdy,
Is there another recommended tractor hydraulic/transmission fluid that meets Bobcat standards that I can use in my CT230 in lieu of the "company" brand?
thanks,
george
Whoops, one more thing, I have found a list of fluids from prior messages with similar questions. The new question is: Can I mix those fluids (Mobile 424) with the Bobcat fluid or should I do a complete changeover? Unlikely that a completely changeover would give me 100% Mobile 424.
george
   / hydraulic/transmission fluid? #3
Walmart has Shell Spirax, the Donax TD replacement. It is recommended for the orange and red Daedong tractors, McCormick, Kioti, etc. I don't know if it's ok for the Daedong tractors if they are painted white.
If you ever hook up your hydraulics to a cylinder or implement that another tractor hooked up, you will mix more that will be left in a change. In my opinion, you are worrying too much.
1982 LeeBoy Motor Grader (A53472)
1982 LeeBoy Motor...
New/Unused Two Post Car Lift 10,000lbs (A51573)
New/Unused Two...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53472)
NEW HOLLAND 706 30...
2014 MAGNUM PRODUCTS LIGHT TOWER (A52472)
2014 MAGNUM...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
