hydraulic/transmission fluid?
   / hydraulic/transmission fluid? #1
george88
Howdy,
Is there another recommended tractor hydraulic/transmission fluid that meets Bobcat standards that I can use in my CT230 in lieu of the "company" brand?
thanks,
george
Whoops, one more thing, I have found a list of fluids from prior messages with similar questions. The new question is: Can I mix those fluids (Mobile 424) with the Bobcat fluid or should I do a complete changeover? Unlikely that a completely changeover would give me 100% Mobile 424.
george
   / hydraulic/transmission fluid? #3
Walmart has Shell Spirax, the Donax TD replacement. It is recommended for the orange and red Daedong tractors, McCormick, Kioti, etc. I don't know if it's ok for the Daedong tractors if they are painted white.
If you ever hook up your hydraulics to a cylinder or implement that another tractor hooked up, you will mix more that will be left in a change. In my opinion, you are worrying too much.
2014 Chevrolet Silverado 1500 Pickup Truck (A51692)
2014 Chevrolet...
378590 (A51573)
378590 (A51573)
JOHN DEERE 5115M TRACTOR (A51243)
JOHN DEERE 5115M...
JOHN DEERE 5083EN LOT NUMBER 136 (A53084)
JOHN DEERE 5083EN...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
Simpson 3400 PSI Pressure Washer (A51573)
Simpson 3400 PSI...
