Hydraulic/Trans drain plug on F16d?
   / Hydraulic/Trans drain plug on F16d? #1
jimmer2880
Platinum Member
Hagerstown, MD
'05 Kubota BX1830
I know this sounds like a very stupid question. But, for some reason, I just cannot find a drain plug on my F16d for the hydraulic/transmission fluid.
Also, I'd like to clear the pickup screen while I'm at it. Does anyone happen to know how to do that? I suspect, it may be a simple as somehow pulling the filter mounting bracket off?
   / Hydraulic/Trans drain plug on F16d? #2
The drain plugs are under the bottom of the axle housing back by the pto shaft. The hydraulic screen is on the left side of the transmission @ about 7 o'clock looking at the left brake housing. Remove the 3 screws and pull the screen out. The F16D also has a spin-on hydraulic filter, I would replace with an OEM filter.
Danny
Thank you very much. I hadn't looked that far back. I'll check this afternoon.
As far as the screen goes, I was wondering if that was it.
I was planning on changing the oil, and the filter, and cleaning the screen. WOW - that filter was expensive. I couldn't believe it. $60.00 at Napa. OUCH!
   / Hydraulic/Trans drain plug on F16d? #4
That's more than the OEM filter, be careful buying an aftermarket filter, some of the dealers are selling a one filter fits all for the F series and it may be too long for your F16D.
Danny
2016 John Deere Gator 825i 4x4 Utility Cart (A53421)
2016 John Deere...
18-1 gallon jugs pure Anti-freeze (A53117)
18-1 gallon jugs...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
ALLISON TRANSMISSION (A53843)
ALLISON...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
