Hydraulic Toplink?
/ Hydraulic Toplink? #1
slinger
I have a BX2330 and need to purchase Cat 0 hydraulic toplink, can't seem to find them. Help!!!!! /forums/images/graemlins/confused.gif
/ Hydraulic Toplink? #3
You mean a top link that has 5/8" pin holes right?
Good luck. I don't think you will find any. Use a more common cat 1 link that has 7/8" pin hoses and use reducer bushings. TSC probably sells the bushings.
/ Hydraulic Toplink? #4
After I sent that message I knew I messed up, it's a BX2230, but you knew that? The trouble is that the pin, center to center, closed can only be about 13". I seen one for Cat 0 at a Kubota dealer about a year before I bought this tractor. So I know they are out there, but just can't find them.
/ Hydraulic Toplink? #7
The retracted length of the top link has nothing to due with the category 0 or 1 specification. The category specification deals with pin diameters and spacing between lift pins and top lin pin.
I am sure a BX2230 owner who has purchased a hydraulic toplink will chime in with where they got it. However, don't expect to get an exact match with respect to the retracted length.
/ Hydraulic Toplink? #8
4004SFL (A59228)
4004SFL (A59228)
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A61572)
2023 ASV RT-25...
UNUSED ATSPOWER GASLESS WELDING MACHINE (A64281)
UNUSED ATSPOWER...
2014 Ford F-150 Ext. Cab Pickup Truck (A61573)
2014 Ford F-150...
Mini Skid Steer Mount Plate, 5/16" Thickness (A62679)
Mini Skid Steer...
UNUSED WOLVERINE HYD AUGER (A64281)
UNUSED WOLVERINE...
