Hydraulic toplink for Kubota L4300
   / Hydraulic toplink for Kubota L4300 #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I have a Kubota L4300and want to get a hydraulic toplink (top-n-tilt) for it. The question is, do I get one with a check-valve built in or does the tractor itself have a "check valve" built into it? I already have outlets on the back. It's much cheaper to get one without the check valve.
I would think the cylinder would drift down on it's own but am not sure.
Anyone have any experience with this general type of Kubota and a hydraulic top link? I would think most of the L's would be faily similar>
   / Hydraulic toplink for Kubota L4300 #2
Same as your question in the JD section; buy cylinders with check valves if you want them to stay. Want to buy some factory Top n Tilt cylinders from Kubota that are only very slightly used? They work just fine, but I came across a deal on two others with check valves far cheaper than I could have check valves installed on the Kubota factory cylinders.
2013 Audi Q7 AWD SUV (A51694)
2013 Audi Q7 AWD...
2011 GALYEAN 130BBL VAC TRAILER (A52472)
2011 GALYEAN...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51248)
KNOW BEFORE YOU...
JOHN DEERE LOT IDENTIFIER 110 (A53084)
JOHN DEERE LOT...
JOHN DEERE S780 LOT IDENTIFIER 36 (A53084)
JOHN DEERE S780...
2022 Ford Explorer SUV (A51694)
2022 Ford Explorer...
