Hydraulic Top N Tilt
   / Hydraulic Top N Tilt #11
I get it! I have always used the power beyond. Are the ports you use the same ones that the rear remotes hook up to? I don't see them? I think the rear remotes use them and that is why I can't find them?
I'm sure he used the same ports as the rear remotes.
   / Hydraulic Top N Tilt #13
BobQ said:
I get it! I have always used the power beyond. Are the ports you use the same ones that the rear remotes hook up to? I don't see them? I think the rear remotes use them and that is why I can't find them?[/QUOTE
I posted to this earlier today, but it is gone.
Almost certainly so.
Your back-hoe probably uses them and it is likely that your rear remotes are in the same loop. Right hand side, just in front of the rear axle's center-line, quite high up. If you have two hoses coming out of there and going either to your hoe or rear remotes - those be they.
1995 OTTAWA SPOT TRUCK (A50459)
1995 OTTAWA SPOT...
2019 TOYOTA 8FGCU25 PROPANE FORKLIFT (A51222)
2019 TOYOTA...
Blue-Jet Liquid Fertilizer Applicator (A51039)
Blue-Jet Liquid...
Toro 30495 Groundsmaster 7200 72in Zero Turn Mower (A48082)
Toro 30495...
2017 UTILITY VS2RA 53FT REEFER TRAILER (A51222)
2017 UTILITY VS2RA...
3000 Gallon Black Poly Water Tank (A49461)
3000 Gallon Black...
