Hydraulic Top link
   / Hydraulic Top link #31
It's just a double pilot operated lock valve that goes between the cylinder and directional valve, it stays in the closed position until a certain pressure is applied to one of the ports on the valve (usually a couple hundred psi, that is the pilot pressure) which allows the valve to open and operate. It's very simple, 2 ports in and 2 ports out.
It's the little square looking block that's barely visible on my top link.
Does it solve the leak down problem?
Are they fairly easy to install?
Where do you get one?
   / Hydraulic Top link #32
If the leak down is in the control valve then yes it will prevent the cylinder from moving.
They can be easy to install, just needs to be inline with the hoses so the 2 hoses from control valve go to lock valve, then 2 hoses from lock valve go to the cylinder.
My top link came with the lock valve installed, but you can buy them from Surplus Center, this one uses npt ports but is rather large https://www.surpluscenter.com/Hydra...k-Valve-1-2-NPT-25-GPM-3000-PSI-9-5606-50.axd
This is the same valve that comes with the surplus center cat. 1 top links
https://www.surpluscenter.com/Hydra...Kit-For-AMA-Top-Link-Cylinders-9-7682-KIT.axd
Just requires some creativity to adapt it to other cylinders as it uses some metric fittings and tubing sizes on the outlets.
2006 CHEVROLET SILVERADO 3500 FLATBED (A58214)
2006 CHEVROLET...
1770 (A58375)
1770 (A58375)
Mini Skid-Steer Stump Grinder (New/Unused) (A59225)
Mini Skid-Steer...
2017 CATERPILLAR 305.5E2 CR EXCAVATOR (A52709)
2017 CATERPILLAR...
2025 14ft Bi-Parting Gate (A56859)
2025 14ft...
New/Unused Electric Golf Cart (A57453)
New/Unused...
