geblackwell
Bronze Member
I have a NH TC40DA and want to install a hydraulic top link from Carter and Carter Machinery. Will I have to put a flow restrictor in line like I did for my grapple?
geblackwell said:I have a NH TC40DA and want to install a hydraulic top link from Carter and Carter Machinery. Will I have to put a flow restrictor in line like I did for my grapple?
6sunset6 said:Where did you get the restrictor ? . I have been looking and have not found one, Installed 1/4 hoses ,did not help much. top cyl and thumb on the bucket
oh yeah I think you will need a restrictor
geblackwell said:The one I used is adjustable and came from Surplus Center
jinman said:Mark Carter warned me that the orifice will send out a jet of fluid when in operation. That jet can eventually cut the inside of the hose. I think this would take a lot more use than our toplinks, but he suggested a right angle adapter after the inline restrictor so the jet hits metal instead of the inside surface of the hose.
Diesel-ME said:Just curious if the flow restrictors cause any fluid heating issues...?? Or is that not a big deal in this type of application?
~Paul
kennyd said:Not in this application, unless the toplink is cycled continuously. But you are correct, they could cause fluid to heat up.
