Hydraulic top link questions
   / Hydraulic top link questions #1
txhawg
East Texas
JD 2305
I’m going to try to piece together a poor mans hydraulic top link. I have the JD 3rd scab kit installed on my 2013 3520, so it has the updated hydraulics. I found this cylinder, which I think should work
Anybody have any experience with that cylinder?
What length hoses should I look at getting? Is 2 feet long enough?
What size restrictor should I be looking at?
Any help is appreciated.
   / Hydraulic top link questions #2
You usually get what you pay for...I have one from Agri-supply like in the link...it did not take long for the weld on the rod end (eye) to fail...for me it was no big deal as I needed to cut a couple inches off the rod anyway so it saved me cutting the eye...just had to grind it a bit...
use a piece of wire etc. to gauge your hose lengths...
Buy a cheap (small orifice) restricted fitting and if it's too slow drill it out some...
Good luck...
   / Hydraulic top link questions #3
   / Hydraulic top link questions #4
That cylinder will likely work,
however you are relying on the tractors valve to have no leakage.
Good luck with that. Many top link cylinders will have a lock valve on them which will take the load off your
tractor valves.
As the link posted above has.
   / Hydraulic top link questions #5
Thanks guys.
There isn't a standard length hose for the top link?
   / Hydraulic top link questions #7
Maybe if factory items are used but my install was all custom. i order top link and installed. Then used a spare hose to figure out the length when placing the top link in up and down position on the 3 point. I can share the thread if you want to read it.
   / Hydraulic top link questions #8
I bought mine from Fit Rite. Been in constant use for eight years now. It's a Cat 2 and never been a moments problem.
   / Hydraulic top link questions #9
category 2 hydraulic top link on mine, brand is Maxim , no lock valve on mine and I really don’t think a lock valve should be needed ? The only issue I’ve had was I lost the bushing that converts it to category 1 pretty quick but Fleet Farm sells the bushing for $1.69 so it was no big deal, I’ve just been a little more careful not to loose it again. I find the Hydraulic top link very handy.
   / Hydraulic top link questions #10
"very handy" - yes. In making implement connections. But particularly in fine tuning ground engagement implements. No longer have to go thru the tedious steps to make adjustments. On-the-go adjustments. Adjust until the implement is performing to its maximum.
2018 Bobcat T595 (A47384)
2018 Bobcat T595...
72" HYD QUICK ATTACH GRAPPLE (A51406)
72" HYD QUICK...
2019 Ford F-550 4x4 Ext. Cab Chipper Truck (A51692)
2019 Ford F-550...
2007 Ford F-450 Ambulance (A55788)
2007 Ford F-450...
2014 Ford Escape AWD SUV (A55853)
2014 Ford Escape...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A55314)
2020 New Holland...
