Hydraulic Top Link Pictures--Looks adjustable?
   / Hydraulic Top Link Pictures--Looks adjustable? #2
It is the same as most non-hydraulic top-links - a screw mechanism where both ends are screwed into the center sleeve. Turn the center sleeve to lengthen or shorten it.
I see what you're saying now after noting the threads. The plated rod still throws me a bit, however, as well as the serrations in the casting. I assume the rod is used to turn the adjustment and then stored as shown? Looks like an elegant method of allowing the rod to rotate ninety degrees between operating and storage position. Maybe I'm just overthinking it.
   / Hydraulic Top Link Pictures--Looks adjustable? #4
It's common to see those on older JD tractors. My neighbor has one on his 4040.
2001 Bobcat 337 Mini Excavator (A51573)
2001 Bobcat 337...
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
5ft Rotary Tiller (A51573)
5ft Rotary Tiller...
2002 Western Star 4900 T/A Galbreath Rolloff Truck (A51692)
2002 Western Star...
JOHN DEERE 9R640 LOT NUMBER 252 (A53084)
JOHN DEERE 9R640...
2025 JOHN DEERE X350 LOT NUMBER 166 (A53084)
2025 JOHN DEERE...
