Hydraulic Top Link for G-Series
   / Hydraulic Top Link for G-Series #1
iah
Fairbanks, AK / Cantwell, AK
2017 Toolcat 5610 , 2014 Toolcat 5610
Hi,
I have purchased a used 5610 and plan to install a hydraulic top link. The machine is still in the lower 48 and I am in Alaska so I can't measure what the nominal top link length is. I was wondering if anyone has recently installed a top link and would be willing to share the cylinder specs for what they used, assuming it turned out well.
Also did you find it necessary or desirable to install a flow orifice in the hydraulic circuit for top link control?
Thanks
Ian
   / Hydraulic Top Link for G-Series #2
No info on a hydraulic cylinder. Measured the top link at 19-1/4 to 28-1/2 inches. The 3/4 inch pin hole is 1-3/4 wide. The bracket that the pin goes through is only 1/16 wider.
Please keep us posted on your project.
Thanks Xfaxman.
Looks like I need a cylinder with an 8" stroke and an overall length of about 28".
Will do.
   / Hydraulic Top Link for G-Series #4
Just got one from Princess Auto. Make sure you get one with a swivel on both ends like a basic top link and search around for 'top and tilt"info. The tilt cylinder replaces the lift arm and will allow you change the horizontal angle of the blade as well.
Al
I'd had seen this,
He is listing twenty week lead time.
   / Hydraulic Top Link for G-Series #7
Have you seen this one: 2x8.25x1.18 Category 1 Hydraulic Double Acting Top Link Cylinder AMA :cool:3 | Tractor Top Link Hydraulic Cylinders | Hydraulic Cylinders | Hydraulics | www.surpluscenter.com
Yes, I decided to go with the one that had an 11" stroke. If it ends up being to long it is easier to shorten than stretch.
   / Hydraulic Top Link for G-Series #9
Here is one way to make it longer, A top link extender:
I hadn't seen that before, looks functional.
2012 Club Car Carryall 1 Utility Cart (A51691)
2012 Club Car...
2007 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2007 Ford F-150...
(10) IH Suitcase Weights (A50515)
(10) IH Suitcase...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
2015 GMC Yukon XL Denali SUV (A50324)
2015 GMC Yukon XL...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
