Hydraulic Top Link fittings won’t stop leaking?
   / Hydraulic Top Link fittings won’t stop leaking? #1
MacFacts
Killeen
2002 TC18
Hello, I have a New Holland Workmaster 25 with a hydraulic top link. The top link fittings started leaking and I can’t seem to tighten them enough to stop it. I tried to tighten the fittings on the cylinder and they still leak. I have taken them apart and don’t, see any type of compression rings or o rings? Any help would be appreciated. TIA
   / Hydraulic Top Link fittings won’t stop leaking? #2
Cylinder packing is shot. Have it professionally rebuilt.
   / Hydraulic Top Link fittings won’t stop leaking? #3
Unscrew the right side in the picture then slide the nut back. Then take a picture so people can what kind of fitting it is. I can think of 3 just off the top of my head.
   / Hydraulic Top Link fittings won’t stop leaking? #4
What? Do you just throw stuff away for the post count?
To the OP, those are compression fittings. If it still leaks after you tried to tighten the nuts, there is most likely something wrong with the fitting or the ferrule that gets crimped on the end of the tubing.
   / Hydraulic Top Link fittings won’t stop leaking? #5
I suggest disassembly of leaking fittings then coat threads with thread sealer & reassemble.
Thank you, I’ll do that.
Thanks I’ll try that.
   / Hydraulic Top Link fittings won’t stop leaking? #10
You need a new ferrule, you might have to cut the old one off. Just go easy and not miss up the tube. If the tube is smashed you well have to put on a new tube.
2009 International Frazer Bilt X-514 Ambulance (A52377)
2009 International...
BUSH HOG 2820 LOT NUMBER 128 (A53084)
BUSH HOG 2820 LOT...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
2020 CASE IH 110N LOT NUMBER 222 (A53084)
2020 CASE IH 110N...
