dfkrug
Super Member
- Joined
- Feb 3, 2004
- Messages
- 7,667
- Location
- Santa Cruz Mtns, CA
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
I'm not sure I understand how the cylinder will change position if the QD's are disconnected unless either the rod seal leaks or the QD's leak. The double acting cylinders used as hydraulic top links are not balanced - oil volume behind the piston end is larger than oil volume behind the rod end. Even if there is no seal on the piston the cylinder won't move because there is no space for the volume changes. The attached link explains this with illustrations.
The Root Cause of Hydraulic Cylinder Drift
My top and tilt both drift. If I do not want the tilt to drift (spending a day moving large rounds using the rear spear for example), I disconnect the QD's and it is hydraulically locked. Only time I have ever disconnected the top is when using a towed implement that requires both circuits - fold and raise our cultivator for example.
Note Casey's 2nd exception in the above link:
"The second exception involves a load hanging on a double-acting cylinder (Figure 2). In this arrangement, the volume of pressurized fluid on the rod side can easily be accommodated on the piston side. But as the cylinder drifts, a vacuum will develop on the piston side due to unequal volumes, and depending on the weight of the load, this vacuum may eventually result in equilibrium that arrests further drift."
This vacuum occurs only when allowing a load to extend, rather than compress a DA
cylinder, and this vacuum leads to air being sucked into the gland seal. Maybe not much,
depending on how good the piston seals are. If the piston seals are not "perfect", the
vacuum is transferred to the rod side.
So you can get cylinder extension drift, even with check valves or disconnected QDs.
