Hydraulic top link cylinder screeching
   / Hydraulic top link cylinder screeching #1
MikePenske
2001 KIOTI DK45
Hello All! First Post, long time lurker.
I have a new, hydraulic top link (with check-valves) installed on a Kioti DK45. When dropping (pushing/extending) the link when loaded heavy (2000 lbs gravel), it screeches. It rated at 14,000lbs push/pull, 3 inch, cat 2. It only makes noise under these conditions. Operation is linear/smooth and all inputs are at idle. Any thoughts/experience would be appreciated. Thank you, Mike.
   / Hydraulic top link cylinder screeching #2
Welcome to TBN and the forum, Mike. Are you sure it's the top link and not the implement it's connected to.
Oosik, thanks for responding. No, not 100% sure it the top link, but seems to be from the seat. Will have someone drop the bucket tomorrow while I have a hand on the cylinder.
   / Hydraulic top link cylinder screeching #4
Sounds like the P.O. check is seating and unseating when lowering the load this is caused by the load trying to extend the cylinder.
What is happening is check closes pressure builds and pilots it open, load runs away so pilot pressure drops check closes and cycle repeats
An orifice in the rod end to restrict flow will stop this.
oldnslo, thank you, I will look into adding that. Seems like a simple fix 🤞
   / Hydraulic top link cylinder screeching #6
Oldnslo is probably correct if your top link has dual pilot operated check valves. Mine didn't screech but it did chatter badly. A flow restrictor fitting on the rod end fixed it.
gg
2018 Great Dane Freedom LT 102"x48' Flatbed Trailer (A50123)
2018 Great Dane...
40' CONTAINER (A51248)
UNUSED JCT HYD TRENCHER (A51248)
UNUSED JCT HYD...
2020 DEERE 318G SKID STEER (A51246)
2020 DEERE 318G...
Mccormick X6.55 (A50123)
Mccormick X6.55...
UNUSED FUTURE FT-80R RIDE ON TROWEL (A51248)
UNUSED FUTURE...
