Hydraulic Top and Tilt help
   / Hydraulic Top and Tilt help #1
Haydro
LS MT3 42
Greetings.
I own a LS MT3 42. I am looking to purchase a Hydraulic Top link and a Hydraulic Side link.
I am running in circles, so I am looking for help and guidance.
Cat 1 Top Link:
1. Pin hole sizes: 3/4"
2. Length of mechanical top link: 16.9 - 25.7 in
Side Link:
1. Fork ends both sides
2. Pin hole sizes: Top is 3/4", bottom is 5/8"
3. Length of mechanical side link: 17.7 - 22.2 in
I have valve type couplers.
Any help would be greatly appreciated.
   / Hydraulic Top and Tilt help #2
I have a 3 57, I bought my hydro top link on eBay, cat 1. Never thought about the side link....
   / Hydraulic Top and Tilt help #3
Top links are fairly generic as long as the extended/retracted measurements work...
...Side links are usually a different story...look at the static side link and see if the angles of the forks (where they attach) are the same...usually they are different top and bottom...
A lot of guys that make their own side links cut the ends off their OEM static side link and weld them on a cylinder...
   / Hydraulic Top and Tilt help #4
Greetings.
Cat 1 Top Link:
Side Link:
With the LS side link, you will not be looking for the complete unit as you have pictured, just the part that is below the lower pivot point as I have pictured.
I don't think that you will find a hydraulic top link to match what your manual top link is.
I recommend that you look at the following link, get the asked for pin-pin distance and get a hydraulic top link that has that asked for dimension as the mid stroke or as close as you can find.
Here is that link. Top link
Electric Golf Cart (A56859)
Electric Golf Cart...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
2017 Chevrolet Ambulance (A55973)
2017 Chevrolet...
2007 Chevrolet Silverado 1500 Single Cab Pickup Truck (A55973)
2007 Chevrolet...
2015 FREIGHTLINER M2 TANDEM AXLE 24FT FLATBED (A57880)
2015 FREIGHTLINER...
CASE INTERNATIONAL 5140 TRACTOR (A52707)
CASE INTERNATIONAL...
