Hydraulic Tip 'N Tilt
/ Hydraulic Tip 'N Tilt #141
Re: Hydraulic Tip \'N Tilt
Bird, I just bought a D490 Zoom. Olympus is offering a FREE USB reader to anyone purchasing a D460 or a D490 up till 02/01/01 (I think there are a couple of other models as well under the offer). I bought mine from a Ritz Camera shop locally. They gave me a form to fill out and send in. The form says it may take up to 6 weeks to get the reader, but it's better than buying one for about $50. The offer is from Olympus so it ought to be available from where you bought your camera. Good Luck. BTW, downloading through the serial port is not as slow as I've been led to believe. It actually works pretty well.
P.S. - The rest of you guys with your fancy tractor pictures are the reason I spent $500 for a digital camera, so I could post a picture or two of mine. That's about $250 a picture... And I thought I bought my tractor to save a few $$$....
Corm
Corm, I considered the 490 ($100 more money than the 460), but decided the one additional feature wasn't worth it to me; although I can see how it would be to some people. I bought mine at Circuit City; guess I'll have to call that salesman tomorrow and ask about that offer of a free reader.
Bird
/ Hydraulic Tip 'N Tilt #143
Bird -
Yeah, go for the reader if it's free.
Even if you're out of serial ports or don't have USB, you can probaly add a USB port or two for minimual bucks.
The mail-in form is downloadable from the Olympus web site. It only mentions the 490 in the blurb, but it's worth checking out.
If you get it and can't use it, I know of a few other Olympus owners who would be glad to take it off your hands, old pal, old buddy. /w3tcompact/icons/laugh.gif
/ Hydraulic Tip 'N Tilt #144
Harv, great camera site. Lots of models to compare. I especially liked the links to the consumer reviews. The Pentax EL 200 is quite nice. A little out of my range though./w3tcompact/icons/frown.gif My standard 35mm point and shoot is a Pentax. I hear ya on using the USB cable. The port is kinda hard to get to. Could leave the cable hooked up I guess. And get an AC adapter to power the camera with so that my wife won't use up all the batteries with her eBay picture work./w3tcompact/icons/wink.gif Can you believe it, John Deere stopped one of her auctions once./w3tcompact/icons/mad.gif
/ Hydraulic Tip 'N Tilt #145
My digital photo taker has a USB port and the software that came with the phototaker allows for very fast down loads. I have down loaded more than 10 pictures in less then 1 minute. The first time I used it I was suprized in the speed. I have a Fujifilm 1400Zoom Camera. Love it.
Dan L
/ Hydraulic Tip 'N Tilt #146
Just to be clear on downloading directly from the camera to the computer --
Some Olympus camers, like mine and Bird's use the old RS-232 kind of serial port. That's the one that is reportedly slow.
Other cameras are now using the more modern USB serial ports, which are quite a bit faster.
/ Hydraulic Tip 'N Tilt #147
Slow is what they told me about down loading from my Cannon to the computer. So I got a reader. It's as fast or it seems as fast as a CD. But its probably not. It's a flashpix card by the way.
JerryG
Yep, Harv, the free reader is apparently only for the 490; not the 460./w3tcompact/icons/frown.gif
Bird
It's probably not the best time, since we've had nothing but cold, rain, and mud lately, my poor tractor is filthy, and the lighting wasn't the best where it's parked in the shop, but I thought I'd try posting a picture of the Tisco valve I used for the tip 'n tilt.
Bird
Well, since that worked, I'll try a picture of the cylinders.
Bird
Getting a picture of that rear hydraulic outlet (through the hoses and other obstructions) was a little more difficult, but we'll see how it looks. It's under the brace called a fender stay, so you can't immediately put a 90 degree elbow coming up, and if you attach straight hoses, you have to bend them up pretty quickly or you're back to ROPS
Bird
/ Hydraulic Tip 'N Tilt #152
Bird, great pictures! You mentioned earlier you had to bend one of the points of attachment of the cylinder so things wouldn't bind- is that the end on the right lower 3 ph arm ? Did that tend to misalighn the holes? I'm getting the itch to do this to my FORD 1910. I'm wondering if there is a smaller valve setup available, especially since you are putting in flow restrictors anyway?
RCH
RCH, the top of the side cylinder was straight instead of being offset, so I bolted on a couple of offset pieces of steel to attach the top end of that cylinder to the lift arm. Everything is too strong to do any bending (unless you heated it with a torch and maybe do some serious damage).
If you look between the hoses to the side link cylinder, and just above where the top hose connects, you can see the shiny bolt. The pieces I bolted on were some that I had on hand and were already painted black just like the cylinders.
Bird<P ID="edit"><FONT SIZE=-1>Edited by Bird on 01/19/01 09:08 PM (server time).</FONT></P>
/ Hydraulic Tip 'N Tilt #154
Nice work on the TNT. Where is the "filth" you were complaining about? Looks clean to me. Glad you have the new camera--you're going to love it!
/ Hydraulic Tip 'N Tilt #155
Bird, I see what you are refering to. So does this added 2" or so of length to that cylinder? Could this mess up the geometry if it was a tighter situation; or prevent the lower arms from being adjusted higher? I have a tree planter with a 22" coulter and I have to adjust the lower arms as high as possible to get that coulter to clear the ground when I lift it up. I do this by attaching the vertical lift arm( or in this case the 'tilt' cylinder) to a hole furthest out on the 2 horizontal arms that have the cat. 1 pin recievers. Put another way is the whole tilt assembly when retracted as short as the adjustable link on the other side when it is fully retracted ?
RCH<P ID="edit"><FONT SIZE=-1>Edited by Rch on 01/19/01 09:54 PM (server time).</FONT></P>
RCH, let's see if I can explain this. Originally, the "fixed" link on the left side was 17" long, and the manually adjustable link on the right side was about 17" when it was centered, so it could go up or down from there. Now I've moved that adjustable link to the left, and put the hydraulic link on the right. The hydraulic link was 13" collapsed, if I remember right, with a 3.5" stroke. The extra pieces I bolted onto it actually lengthened it about 3", which I felt made it about the right length anyway. So what I've done right now (may change later after I use it awhile) is to set the hydraulic cylinder right in the middle of its stroke, then adjusted the left link to the same height so they're level. So now I can hydraulically raise or lower the right arm only about 1.75" from level. Of course, 1.75" at the arm makes the ends of the box blade move up and down considerably more than that, and I can tilt the blade both directions. And of course, if I need more than that, I can always re-adjust that manual link on the left and really get a drastic tilt in either direction.
So, I guess the answer to your question is, "No, the hydraulic link will not retract as short as the manually adjustable link, but it will retract as short, or shorter, than the fixed link that was originally on the left side."
Bird
/ Hydraulic Tip 'N Tilt #157
That's a very nice setup Bird! I've only seen a couple of tip and tilt setups up close, but on both of them it seemed there was lots of extra hose, making them look real messy. Yours is nice and neat. You're doing the TBN proud! /w3tcompact/icons/smile.gif
That camera takes real nice pictures. It's making me anxious to break mine out of the box and play with it. Sorry the free reader deal wasn't for your model.
Corm
/ Hydraulic Tip 'N Tilt #158
Bird -
Your pictures are terrific!!! Really terrific! /w3tcompact/icons/smile.gif
I might be almost as thrilled with your new camera as you are. /w3tcompact/icons/laugh.gif
After all this time, we finally have a "window" into your world, way down there in Texas! I live with this kind of technology every day, but I never cease to be amazed at the things we can now do. Thanks to you and a few more up-and-coming digital camera enthusiasts, this board has just increased it's value even more.
The picts you just took are now resting comfortably in my own digital library of tractor stuff on my own hard drive way out here in Californy. I will probably bring prints with me the next time I visit that Kubota mechanic I told you about. This is too cool. /w3tcompact/icons/cool.gif
As to why your images look better when posted -- apparently your browser is doing a better job of rendering the jpg images than your editing software, which surprises me. Is it possible that you were viewing them at a different scale (maybe 150% of normal size), or a different color depth (maybe 256 colors) or something like that? You can use your browser to view image files on your own hard drive, if you want to do a little comparing.
What software are you using?
/ Hydraulic Tip 'N Tilt #159
I have noticed that with some photo programs, particularly Microsoft Photo Editor, that the .jpg files look pretty crappy at LESS than 100%. In theory that makes no sense but it's really true. Look at the display size, and if it is not 100%, change it to 100% and you'll see an amazing resolution difference. Of course, it may be too big for the screen, but that is a different problem that can be fixed also.
Larry...
Harv & LarryT, I've still got much to learn about digital photography. The software I'm using so far is what came with the camera from Olympus; Camedia? It's worked pretty well for lightening photos that appeared to be too dark. And I thought if a photo was taken at, say 1280x960 resolution, you could "shrink" it with the same resolution; just packed tighter together? Anyway the only way to "resize" that I've found so far is to reduce the number of pixels, which is what I did to those photos; took them down to 640x480. So now I know about what size they will appear on the screen, but to know what size they would print, I just have to print one to see. Oh well, I'll learn more as I go.
Bird
2025 Auger with Bits Mini Skid Steer Attachment (A66734)
2025 Auger with...
INDUSTRIAS AMERICA 2426 - 10' OFFSET DISC HARROW (A64277)
INDUSTRIAS AMERICA...
WHOLE PARTS ROOM (A68842)
WHOLE PARTS ROOM...
HELI 5K FORKLIFT (A67714)
HELI 5K FORKLIFT...
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
Unused Land Pride SGC1560 Hydraulic Claw Grapple Skid Steer Attachment (A66734)
Unused Land Pride...
