Hydraulic Tip 'N Tilt - OK, Top 'N Tilt
   / Hydraulic Tip 'N Tilt - OK, Top 'N Tilt
Re: Hydraulic Tip \'N Tilt - OK, Top \'N Tilt
hayden, you're right, but to me it's not important. The FEL has the power beyond setup, so it doesn't interfere with the operation of anything else. Then I used the other hydraulic outlet for my Tip 'n Tilt and did not use the power beyond on the valve, so as you say I cannot be adjusting the tip or tilt and raising the 3-point simultaneously. And I can't forsee ever having any need to do those two thing simultaneously, so it just doesn't matter.
Bird
   / Hydraulic Tip 'N Tilt - OK, Top 'N Tilt #52
I wish I could have explained it that well.
Brian
2018 Peterbilt 389 Wet Kit T/A Sleeper Cab Truck Tractor (A55973)
2018 Peterbilt 389...
1998 6X12 Utility Trailer (A56859)
1998 6X12 Utility...
2023 Kubota Z412KW Zero-Turn Mower with 3-Bag Bagger System (A56435)
2023 Kubota Z412KW...
1995 Ford 3930 50HP Utility Tractor w/ Land Pride RCD1884 84in. Brush Cutter (A55973)
1995 Ford 3930...
New/Unused Quick Coupler (A57454)
New/Unused Quick...
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
