Hydraulic system
/ Hydraulic system #1
JackNixon
Kinder, Louisiana
Zetor 5211
I am having trouble engaging the hydraulics to raise the rear lift arms. I am confused with the position of the levers on the floor between my feet. The tractor PTO has worked in the past as well as the lift arms for implements in the rear and I am not sure what is wrong. We replaced the hydraulic pump, thinking that was the problem but there has been no change in operation and the lift still doesn't work. Also, the two levers I am talking about are loose and sloppy. Is something broken in there?
/ Hydraulic system #2
The hydraulic pump is in the bottom right rear of the housing so you pulled the seat and top cover of the housing off to get to the pump. I have never seen a pump bad but it could happen. Does the pto clutch lever work correctly. Are you pulling it up and does it lock in place before you try to move the lever.
Remember the right lever is high and low on the transmission and only the left is PTO and hydraulic engagement.
23105 (A56859)
23105 (A56859)
SALTYS MANFUFACTURING 500BBL FRAC TANK (A58214)
SALTYS...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A61306)
2016 RAM 5500...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2005 Kubota L3130 (A60462)
2005 Kubota L3130...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A61307)
Neckover GL24-2-7K...
