Hydraulic System Oil
   / Hydraulic System Oil #1
phoenix94
My Ingersoll 6020 calls for 20W40 motor oil in the hydraulic system. Trouble is nobody in town carries it. They've got 15W40 though. Would it be alright to use this instead? If so should I drain first or can I just add. Thanks.
   / Hydraulic System Oil #2
I would think you could just add?:confused::)
But that does not mean it is correct.:)
   / Hydraulic System Oil #3
20W-40 is most commonly a motorcycle oil, beyond that it's kind of an oddball. Did you try a motorcycle shop?
I know AMSOIL also makes it in synthetic, others may also.
If you're mostly using it in a warm climate, I wouldn't think 15W-40 would make much difference, it's only a slightly thinner base.
Also probably a heck of a lot cheaper since it's readily available most anywhere.
   / Hydraulic System Oil #4
The oil companies change their products with the times. Old machinery doesn't.
It makes for some creative substitutions as the decades pass.
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A52706)
UNUSED CFG...
40 SEA CONTAINER (A53843)
40 SEA CONTAINER...
2016 FREIGHTLINER CASCADIA DAYCAB (A53843)
2016 FREIGHTLINER...
2008 CATERPILLAR 12M MOTOR GRADER (A51406)
2008 CATERPILLAR...
2014 FREIGHTLINER 114SD VACUUM TRUCK (A51406)
2014 FREIGHTLINER...
FORD 555B BACKHOE (A51406)
FORD 555B BACKHOE...
