Hydraulic System Oil
   / Hydraulic System Oil #1
phoenix94
My Ingersoll 6020 calls for 20W40 motor oil in the hydraulic system. Trouble is nobody in town carries it. They've got 15W40 though. Would it be alright to use this instead? If so should I drain first or can I just add. Thanks.
   / Hydraulic System Oil #2
I would think you could just add?:confused::)
But that does not mean it is correct.:)
   / Hydraulic System Oil #3
20W-40 is most commonly a motorcycle oil, beyond that it's kind of an oddball. Did you try a motorcycle shop?
I know AMSOIL also makes it in synthetic, others may also.
If you're mostly using it in a warm climate, I wouldn't think 15W-40 would make much difference, it's only a slightly thinner base.
Also probably a heck of a lot cheaper since it's readily available most anywhere.
   / Hydraulic System Oil #4
The oil companies change their products with the times. Old machinery doesn't.
It makes for some creative substitutions as the decades pass.
2010 THOMPSON TRASH PUMP (A51406)
2010 THOMPSON...
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
1981 LUFKIN FLATBED WINCH TRAILER (A53843)
1981 LUFKIN...
72'' power rake (A53421)
72'' power rake...
2002 WACKER RD25 ROLLER (A54607)
2002 WACKER RD25...
